G
I learned a lot about retractable seat belts this week.
1. When they jamb, do not take the side apart that contains the spring. That 2" diameter spring is about 8 feet long when freed from the housing.
2. So I bought a new set of retractable seat belts. They work and look great in my Mazda. My Mazda truck's seat belts were starting to look pretty crappy anyway.
But that's not the vehicle I needed them for.
Seems that most retractable seat belts will work only when they are mounted in a vertical position close to the floor- as I figured out today, that's so in case the car rolls over or onto its side, the seat belt will lock (I tried it with the seat belt, not the car) The belts will only reel out of the housing in a vertical position.
However in the Midget the seat belts are behind the seat up high. They need to come out of the housing in a horizontal position. I tried every which way of mounting them and couldn't get the belts to work correctly.
Anybody know where I can get a set of retractable belts that will work this way? Seems OEM MG belts are unavailable although the ones in the Moss catalog look the same as the ones I bought.
