Just cannot get the jet to come back up to rest on the front carburetor after I pull the choke on my tr3. I am using cork glad washers I got from Joe in NY and perhaps they are too large and placing everything in a bind as the jet slides back? I have checked all the pivot points and the preload on the arms of the linkage and believe that to be working. I have even undone the leakage after pulling the choke to make sure the problem is at carb. The jet is polished, but will not return comfortably. If I drive the car the jet will sometimes work its way up, but when it does not the mix is obviously too rich. Anybody else have this problem?
