Philthytoo
Member
As I get closer to a paint ready chassis on this TR2 project, my mind begins to question. I've spent a fair amount of time reading posts about correct colors and types of paint/coatings, has anyone tried using tractor paint? I get the POR15 thing, although since I'm starting with a no-rust (been in a garage in So Cal for 40+ years) frame, I'm thinking a quality paint over primer after sand blasting would work fine. This is not a concourse job, just a driver-quality re-build. I recently finished re-doing a Ford 8N tractor for a friend, and the oil-based enamel we used on that seemed bullet proof once it cured.
Thanks, Phil
Thanks, Phil
Hi Guest!
You have gone this far in prepping the frame that you might as well spend the extra $ and use POR15. I had my frame sand blasted and finished it with POR 15. It has held up extremely well. Once the body is on it will be protected from UV rays.
