After spinning a second wire wheel hub on the 73 B I bought a wheel on ebay, advertised as a 14" in good shape. When it arrived it was in good shape, good splines, true and good spokes, so I took it in and had it powder coated in the silver grey color to match my other wheels, and then on to the tire shop to have the tire removed from the old wheel and put on the new one. That's when the bad news came, the new wheel was a 15". I know, I should have checked it before having it powder coated but I made the mistake of trusting the ebay listing. So now I've got over $100 in a wheel that I have no use for. Anyway, I'm burned out on dealing with the splined hubs and wheels, and can't afford to replace all 4 hubs and 5 wheels with new ones, so I've decided to go to a solid wheel. I know I've seen posts here saying that you really should change the entire rear axle to have the correct spacing, but I don't fully understand the implications. Can someone explain to me, is one axle longer than the other due to the design of the two wheel types, and if so which is longer. If I simply change out the splined rear hubs to the bolt on types will the rear wheels be too close together or too far apart? And are we talking about a minor change or more? Or am I totally confused on how these two types differ? Also, if you know anyone looking for a freshly powder coated 72 spoke 15" wire wheel I'd love to talk to them. Thanks.
keith
keith
