Alex Grant
Member
How hard is it to change out the seals for the side axle shafts on the diff. For the tr4a?
The bearing doesn't need to come off (assuming you can get the flange off). The seal is in the retaining plate that you take off before removing the bearing from the shaft.I'm guessing by looking at the shop manual the bearing needs to be removed to get to the oil seal.
Come to think of it, that may be why it worked for me. I've got a pair of press plates that fit perfectly behind the flange. When I modified some plates to fit that well behind the rear hubs (for my solid axle TR), they started coming apart much easier as well.My humble opinion is that taking the axles to a machine shop that doesn't have the fixture to support the flange is a crap shoot.
Understood, Berry. I was replying to Alex, not you. Hopefully I've made that clearer now.Randall-Removing the bearing was an alternative to removing the flange. It is necessary to remove either the flange or bearing to remove the retaining plate with the seal. Kind a novel approach, I thought.
Berry
