Re: Changing points makes me want to change cars..
Hi Adrio,
If you are "really" worried about the Pertronix failing, it is much easier to carry a spare module & replace it than to reinstall points, condenser, terminal block, & wiring changes. Not all that expensive & could save a lot of roadside messing around. A failed unit can easily be determined by the same procedures listed below.
With all engines, the most important controlling number is the maximum advance at high rpm. Let the rest of the advance numbers, including idle, fall where they may.
Additional timing marks can be put on the pulley as needed. Measure or calculate the circumference & divide it by 360 degrees. This will give the pulley circumferential distance per degree of rotation. I would mark the pulley at 5 or 10 degree intervals up to 40 degrees. A fine brush with yellow paint works well. I actually put small notches in the pulley when it was acessible.
The Pertronix can be timed at zero speed. Put a DC meter across the coil primary terminals. Slowly rotate the engine in the forward direction (approach firing) until the meter changes. At the precise firing time in the rotation, the meter will change. Observe the timing marks & advance or retard the distributor as needed. The engine can easily be rotated (bumped) small amounts by putting the transmission in top gear & rotating a front wheel. Lot more leverage & precision than pushing on the car.
Recheck by backing up the engine about 40 to 70 degrees (necessary in order to RESET the electronics & to remove mechanical slack in the distributor drive), rotate the engine forward & watch the meter as the engine approaches the desired timing mark, the meter will change at the firing point.
Do not leave the ignition on with the engine not running for extended periods of time. It will overheat the Pertronix module. About the only thing that will damage the unit, other than wrong connections.
As a final check, with a timing light connected, vacuum advance/retard disconnected, check for somewhere around 32 to 38 degrees advance at 4500 rpm. This number may vary with fuel quality & engine tune & can be set as needed. Obviously you don't want ping. In any case, going over 38 degrees will not improve things & may cause silent detonation.You won't hear ping, but damage is still being done.
Vacuum advance may cause more than this amount of advance, but it only occurs when the engine is partially loaded & is not detrimental.
