Cant be too different from a TR6. Not sure what kind of rotisserie you are using, but on this one with a platform, CG line is just above the lower air intakes at the front and right at the horizontal edge below the license plate area at the rear. Without the platform it would of course be higher.
Ed,
Thanks for the picture and explanation. Like yours, mine is a set of 2 engine stands and I plan on mounting using the front and rear frame mounts. Mine does not have the adjustment yours does, so I need to look into building that.
Thanks, Rut
