dklawson
I will be posting this inquiry in a couple of locations so please excuse the duplication if you come across it more than once.
My wife just bought one of the Caswell Plug-N-Plate plating kits to improve the appearance of some parts on a machine she is restoring. These kits are similar to ones sold by Eastwood and Micro-Mark among others. I of course am going to be watching to see if the results are good enough for me to use this kit on my automotive projects.
My wife and I are both looking at the plating kits for cosmetic work, not heavy or thick plating for wear or permanent corrosion resistance. The particular kit my wife bought was the dual component kit for both copper and nickel. I encouraged her to buy that kit as my industrial experience is that copper is often applied as a flash or tie coat plating between nickel and steel.
My question here is, have any of you used the Plug-N-Plate kits and do you have any tips and tricks for getting good results?
Thanks in advance.
Thanks in advance.
