for what it's worth, I'd pick up the silicon gasket set for the valve cover. The silicon gasket sets typically include silicon gaskets for those side covers. Moss has them, or if you want to save a bit of money you can get them on eBay. The set I have works great, plus their reuseable, so you don't have to get a new gasket evertime you pull off one of those or the valve cover.
just my $0.02 worth /ubbthreads/images/graemlins/smile.gif
Moss has new silicone gaskets especially designed for the side covers. I hear they work pretty good. Just be careful, when you do replace the side covers that you don't over torque them as it can cause them to distort and REALLY leak. As I recall the spec is 4 ftlbs.
I'm using an angle grinder to clean that area up. Chuck's dang air compressor can't keep up. I get less than 30 seconds and it slows and the a/c has to recover, takes about 3 minutes.
Dahubby's birthday is Saturday. He's getting a new air compressor (has been wanting one anyway) I want one of those standing ones. What should I look for, how big?
Don't use angle grinder to clean up anything on the engine that's a machined surface!! If anything, get a thin putty knife & scrape & scrape & scrape...keep that angle grinder away from the engine, Janel!
[ QUOTE ]
[/ QUOTE ]
Oops. Might be jeeest a little too late Tony.
Wire wheel is okay - go to harbor freight & get an assortment of their plastic wheels - if you use hard wire, you'll scratch the metal & then have to sand it to smooth.
I read about a trick for cleaning the gunk out of the side covers: pour a little bit of gasoline into the cover and light it up. When it quits burning, beat the cover against something to knock the burned up crud out.
Replacing the inner mesh can be done using a pot/grill cleaner steel mesh pad or two. Ask JDW about it...
