TR6 Carpet questio
ichthos
I can't remember if I purchased my carpet set from Moss or TRF, but it did not come with wheel well carpet sections. Were the wheel wells originally carpeted? I always see the wheel wells carpeted at the car shows.
Kevin
Do you mean the rear wheel wells? They should be covered in vinyl.
Yes, Darrell, I meant the rear wheel well. I looked at Piggot's book, and you were right-it was originally vinyl. I can't seem o find it in the Moss catalog.
If I recall correctly, it is usually supplied with rear and rear side panel trims. At least I think they were included with mine, both from Moss and later TRF. That would have been for my TR4A, but since the parts are very similar, I would think the kits would be similar.
I bought a carpet set for my bugeye from Moss, and it came with the wheel arch carpet, but the set for my TR6 didn't. I guess I will have to get a pair from Rimmer Bros. unless someone knows of a closer source.
I checked the Moss site, and they are part of the panel kit:
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=32959
I don't see why they would be supplied as part of a carpet set, since they should match your interior trim, not the carpet. I don't seem them listed separately on the Moss site.
You might check with BobbyD, he might be able to make you up a set.
My Wheel arch vinyl came with the panel kit from Moss... You might call them, I have has some luck ordering pieces from them that where parts of a kit. (I messed some things up.. lol...)
