Keith_M
I just finished rebuilding the carbs on my '65 Sprite. Everything seems fine except that I can't get the idle below about 1200 RPM's. I've checked the butterfly valves, and they seem to be seating correctly; i.e., with the carbs off the car, I can rotate the throttle shaft until the valve is completely closed. The angled surfaces of the valve are correctly oriented so that they sit flush on the sides of the throat. The slow running adjustment screws are backed out completely, and the throttle cable is loose so that the throttle shaft definitely is rotated to fully closed.
The carbs behave normally in that I can adjust the mixture to be lean or rich, and I can hear the air entering the mouth of the carb with a listening tube, so the airflow is clearly coming past the jet. This rules out a vacuum leak, I think...
I think this means that air is somehow getting past the butterfly valve despite the fact that it is apparently seated correctly. I just don't see how that is possible. Anybody have any suggestions?
