Novice Bruce here again with 66 sprite. When I got the car the vacuum line from the carb to the distributor was a rubber hose. On the parts car it had a hard plastic line. The plastic line has about a 1/8" opening. Was this the standard line. I could not find in any parts store. Another problem is on the parts car, the vacuum from distributor has a smaller outlet connection for the line. On the one I am restoring, the outlet has a 5/16" thread end. Is the threaded end for some type screw on hose? Help please. thanks Bruce
Hi Guest!
