I just picked up a 79 B and was going through my maintenance checklist when I got to the carburetor damper on my Zenith carb. I tried to check the oil level as stated, but didn't get any reading. So, then I read about topping it off and got even more confused.
After moving the air filter box out of the way, how and what do you remove? Is the damper assembly easily seen at that point? Can you just add oil from the top? And finally, what happens if the oil is empty and/or low?
Help and advice is greatly appreciated!!
