I bought 2 used carburetors from Team Triumph (1973 model)and 2 rebuild kits from Moss Motors. When I removed the bypass valve to replace the gasket I found that the gasket in the carburetor was solid so as to blank out the holes in the valve. The ones in the kit had an elongated hole to allow passage between the holes. I have heard that the difference between the '69 and the '71, besides being able to adjust the '71, is that one is external vacuum and the other is internal vacuum. The ones that I bought have what looks like a large vacuum port on each carb and one small vacuum line on the bottom of one of them. The ones that are on the car do not have the large ports, Only small ones for the vacuum advance.
Can someone help me out?
Thanks, Pete
Thanks, Pete
