Okay - got the correct needles for the carbs finally (original non tapered were wrong) and had the shop check the throttle linkage shafts - which they said were fine. Have also replaced all gaskets again (including manifold) and here are the symptoms now (with 8 degrees before TDC timing and correct gap on the points and car to regular operating temperature).
Idle is still high (about 1200 rpm when it is supposed to be 1000) to get the Uni-Syn to mid gauge (with the center twisted in)
Also, when I place the Uni-Syn on the front carb the idle increases, but not on the rear one (but when check all suspect areas with propane for vacuum leak I get no increased idle.
Once I get the same air flow and go to adjust the mixture (I had to turn both jets down another six flats to start with - past the standard 12 - just get the car to stay running) the rear carb has to be turned down another six flats to get it not to stumble when the piston is raised slightly.
The end result is still a car that is missing and I am getting ready to drive it off the local cliff (never had this issue with any of my cars before)
Any ideas at all are welcome.
Thanks again
Thanks again
