I just finished putting kits in both carberators. When I started to make the initial adjustments I found that Bentley does not address my model. It looks as if the early carbs do not use the adjustment tool and they do not have the deceleration adjustment.
What is the proper way to adjust the mixture etc.? The only adjustments that I see are for the fast idle, choke and what Bentley calls the trim screw. I assume that the trim screw adjusts the mixture?
BTW the commission number is CC25632L
Thanks, Pete
Thanks, Pete
