Gray_Cat
I installed rebuilt carbs on my 55BN1 and have encountered syncronization issues I can't seem to overcome. The car starts fine (1 push of the button) but I can't get it to idle properly below 1800 RPM. The slide action in the rear carb seems to be functioning properly. The slide in the front carb is going up much higher in relation to the rear carb and causes the engine to race. The engine runs great above 1800 RPM but I did notice some very slight backfire - the timing etc. was untouched. Everything was renewed in both carbs except the butterflies, is it possible the one in the front carb is the culprit? I've adjusted the jet nut in all manner of lean to rich and it doesn't seem to make much difference on the front carb. The springs seem fine and the correct amount of dash pot oil (the real thing) has been added. I've tripled checked the linkage etc. as well and seems to be in order. The vacuum is hooked up - is there any possibility the crossover pipe between the front and rear (manifold) carbs has anything to do with this? I've worked a lot with SU's in the past (distant) but this has me mystified. Any help is appreciated!
Oh, any suggestions as to a good shop manual, the original one leaves a great deal to be desired. Many thanks! /ubbthreads/images/graemlins/thirsty.gif
Hi Guest!
