Hello All
Once again I request some insider knowledge.
My TR6 has started to sometimes stay at a high idle when the foot feed is released. Usually tapping the foot feed will get it to drop back down.
What I think I have found. On the rear carb, there is an L shaped arm, this has the throttle stop screw on it, there appears to be two of them, one with a spring that rests against the actuation linkage and one with a nut around it that actuates against this L shaped arm. This arm also actuates a small shaft that goes into the carb body. This small shaft can hang up when returning from a accelerated state to an idle state. Jiggling it allows it to fully return and lowers the idle.
The front carb does not stick in this fashion.
Please see photo, the red pointer is pointing to the L shaped arm and behind the choke cable is the portion of the carb body where the small shaft moves in and out.
https://www.flickr.com/photos/norton47/896411756
What is this small shaft and how might I resolve this issue?
Thanks
Thanks
