mylillooker
I've got a 79 Midget w/a Weber carburetor. I've just recently swapped engines. The carb in the car now is the same one that I was using before.
The problem is that when I start the car the engine revs way up and the dies right out in a matter of seconds. Trying to give it more gas doesn't help. It still dies right out.
We've taken it apart enough to check the float bowl and unscrew and clean the jets, but that hasn't helped the issue.
NOW, if we hold the choke plate closed it does continue to run, but at an incredibly high idle!!!!
When I took the carb off the old engine, I didn't take it off the manifold. I didn't mess w/it at all. It did sit for a couple of months before I was able to put it all back together.
Any ideas as to what it might be? Any questions that could help you diagnose it? Anything...? It seems as though it should be something simple, but what? /ubbthreads/images/graemlins/confused.gif Please don't assume anything, I'm very new to this DIY mechanic stuff.
Winter's here and the bicycle I've been riding ain't cuttin' it anymore!! /ubbthreads/images/graemlins/crazy.gif I need Help!! I need a car and fast!
Thanks,
Mario the auto mechanics idiot!
Thanks,
