64rocksprite
Well, after centering the jets..I found I still had to run the mixture adjustment nuts all the way down to get an idle. 2k rpm is hardly an idle!!
OK, too much air from somewhere..right? Took a can of gumout and starting spraying. As soon as I hit the throttle shaft on the rear carb, rpms increase. Did it 4x to make sure as the "idle" tends to walk up and down on its own.
So..I'm assuming that is where all the air is coming from forcing me to run the jets "rich".
Question now is, do I just ream for the oversized shafts..or go whole-hog and have the $350 rebuild done(which will include that I would guess)?
The carbs seem fine other than this leak at the shafts..if I had the reamer, I'd be tempted to do it myself! These are the original carbs w/ 74Kmi on them (with soft-parts replaced already).
Thoughts? Thanks all..
