Alright, so everywhere I've read on how to adjust the carbs (HS2's) requires you to start the engine and adjust it to run better.
My issue is that it is a new engine rebuild and the car has never ran. After rebuilding the carbs, how do I adjust the carbs to have the engine start up?
From what I can tell, all the fast idle does is open the valve to let some mixture through. How open should this be? How far should it open when the choke is pulled?
Any advice would be greatly appreciated.
Note: I have verified I'm getting a spark so the only thing I can guess is no fuel (also, I'm not smelling fuel).
Hi Guest!
