carb adjustment
69tr
I just finished putting kits in both carbs. When I started to make the primary adjustments I found that there are no adjustments. I guess the early TR6's did not have a mixture adjustment. Are there any adjustments that can be made on the carberators other than the choke and idle speed?
BTW the commission # is CC25632L
Thanks, Pete
Pete - what carbs are you using?
Tom
Tom, I accidentally posted this question twice. It is also under "carberator".
Any way the manual says that I am using 175CDSE carburetor.
