carpecursusII
Bought new carbs from Paltech and installed. Take the car out and open the throttle, it will run but if I put it to the floor nothing happens. The car will run but the RPM with only come up maybe 50-100, there is no acceleration. The car does not misfire and has pertronix installed. It did this before I installed the new carbs so it seems I'm back to square one. I did check the pump and when I spun the starter fuel came out. The car will idle just fine.
Please bestow some wisdom here
Thanks.
Thanks.
