Car goes "click" when trying to start - the fix
OK, this post is sort of like a public "note to self" and also "note to anyone else with this problem. I searched quite a bit for a solution, but never could find the right one online. Maybe if someone else has the same problem, their search will find this post and they will know what to do
The Problem
Your car is running fine, the battery is charged and in general there are no problems. You go out to start it, maybe even just after driving, you turn the key, and all you get is a "CLICK" from under the dash.
What's Wrong
The starter has engaged with the ring and is stuck.
What I Tried Doing
I tried jump starting it (even though I knew the battery was OK). I tried pushing the button on the back of the starter solenoid to turn over the engine. I tried push starting it.
Actually pushing the solenoid button and push starting the car sometimes worked, but I think only by luck that it managed to disengage the starter from the ring gear.
The Real Fix
After having the car get in the "CLICK" mode and me being unable to do any of my tricks to start it, I gave up and had it towed to a guy in San Antonio who used to have the MG dealership down here "back when". He told me what the real problem was, and he told me the fix. OK the fixes. REAL fix is get a new ring gear. But the "Field Fix" is to do this...
1) Put the car in gear
2) Brake off
3) Rock the car back and forth until starter disengages
Now I know.
And now you know.
And now people searching the internet using the kinds of keywords I used may find this post :^)
The Problem
What's Wrong
What I Tried Doing
The Real Fix
2) Brake off
Now I know.
And now you know.
Hi Guest!
