I'm having trouble with the idle on my MGB. I have some suspicions, but wanted to get your opinions.
So when I first start the car up, it doesn't want to idle (RPM drops). After driving for a while, it will usually idle okay, somewhere between 1500 and 1000 RPM. But sometimes as well it will do the same thing and the RPM will drop.
A corollary is that pulling away from a stop the car will bog down sometimes, seems to clear up with a couple stabs of the throttle.
My suspicion is that it's still really rich (I'm at nearly 6000' elevation). Current needles are richer than stock (#6 as installed by PO when the car was in Canada).
What else should I look at?
