bighealeysource
Hey all,
Got a mystery here. My engine runs great for maybe 30 to 45 minutes, usually going somewhere and then stop for whatever reason and then start out again. Like yesterday, ran like a champ going to a club meeting, maybe 30 minutes in. Sat a few hours and on trip back started to miss. I have changed the plugs and even a new coil. Using a Petronix module and it is working fine - understand it either works or it does not as no adjustment there. I just can't figure out why it will run great to start and then later on start missing. I considered a carb issue but runs great at first so unless their is a gremlin out there messing with my SU's doesn't make sense to be fuel/carbs. So, guess it would be electrical. That's the reason I put in new plugs and changed the coil. Using a 3 ohm to go with the Petronix. Anyway, any thoughts or advice would sure me welcomed.
Thanks,
Mike
Thanks,
Mike
