G
Tried the nylon tie, tried the feeler gauge. On the rear bearing, should I loosen the #3 bearing cap a bit to let it "sag" although not sure it will. Will leave the rear cap off overnight. <span style="font-weight: bold">NOBODY</span> in this little burg has green Plastigauge, or any other color for that matter. The clerk at AutoZone said, "What's Plastigauge?" I new I was in trouble.
Want to check the wear, might be able to salvage the bearings. They are 1 over.
