Hello to all - after sitting in the barn for 3 weeks I planned to take the ole car for a drive this afternoon. However, I found that I could not shift the car into gear while the engine was running. I could run through the gears with the engine off. Clutch pedal play/pressure has not changed. Does this sound like a major clutch repair or a possible linkage problem? The car was running quite well prior to this episode. Thanks for any insight you may have. Chris - 69TR6
