Use a die grinder (15k rpm or better) and a good selection of ball grinding points. Mark the old guides with a scratch tool where they protrude into the gas flow venturi, press them out, cut them off at the line and then press them back into the holes they came out of (we had a set just for the purpose in the shop I worked in). Make a gauge ring out of coat hanger wire, less is always more, consistency of diameter is the desired result. Singular most important trick. Buy a long (3/16) drill bit, cut off the drill with a dremel then if your reasonably good with the dremel cut a slot on one end long enough to accept a strip of roll type abrasive cloth and have at it. 120 grit will polish it out nicely in no time. Careful not to pull out the abrasive cloth out while polishing. And I recommend doing this outside and even then using a dust mask and definitely eye protection.
