The Bentley book says to get an initial setting on the timing to raise #1 piston to TDC and turn the cam so that the "machined cutaway" is at twenty past four. It the machined cutaway the one that looks like an oil passage? The cam has a punch mark that is at the bottom when the above mentioned oil passage is at twenty past four.
I am replacing the sprockets so I am having to start from scratch on the timing.
Thanks again, Pete
Thanks again, Pete
