jcatnite
Ok, looks like I botched the first attempt at a caliper rebuild for my 76 Midget. This has been the brake job from you know where and it looks like it just got a little longer. Evidently, when I was pressing the cup back into one of the calipers I pinched the inner seal and even though it bled well, when I put a little brake pressure on with the pedal, fluid poured out of the caliper. Is there proven way to push the cups back into the calipers? I just used a large socked and tapped it in. Felt like it went in straight but like I said, fluid flowed with no feedback on the pedal. I would like to test my rebuild before I go so far next time. Does anyone know what pressures are developed by the system. I suspect it is pretty high but I thought an air rig with a banjo bolt would be a good way to test it before I went through the trouble of putting it on the car and filling the system for the 4th time. There is a story behind each attempt to fill the system...lol
Thanks,
JC
Thanks,
JC
