I'm about finished with the installation of a new wiring harness on my TR-3A restoration. The dynamo is a C40, but I'm unable to see the "F" and "D" terminal labels on the rear of the case. It seems logical that the heavier gauge yellow wire would go to the larger spade terminal with the lighter gauge yellow / green wire routed to the smaller spade. The harness has the old ring terminals which, from what I've been reading, would probably be compatible with the older C39 dynamo. I have a larger spade terminal that will fit.
Since "logic" doesn't always "rule", would someone be kind enough to confirm my suspicion.
Rick...
Rick...
