I'm trying to get past my mental block on wiring here - so thanks for the help!
My fuel pump is current directly wired into the fuse block as shown in the picture. To get the fuel pump running I needed to connect an alligator clip wire to B and A3 terminals. It worked fine like that for about two months, but then earlier this week the fuse blew and now it connecting the clips to B and A3 does not work.
Ideally I'd just wire the fuel pump to the Ignition switch, but that wiring is not stock and not working properly. Starter and plugs are always hot and do not need the combination switch to be turned on.
If I am willing to simply disconnect the battery whenever I am done driving the car, could I move the fuel pump connection to A3?
Thanks again! (I really want to drive her for a bit before I start really digging in).
