This is for Mustafa and Jack. Here's my Bonnet harness, and the wiring to the wipers, as seen from the engine bay.
2 wires to the wiper motor, coming from the firewall.
Connections at the firewall for the bonnet loom.
RHS (passenger) light connections.
LHS (driver) light connections. This is the end of the loom.
If this still isn't making sense, PM me and I'll send you my phone number and I can try to talk you through how my car is set up. I'm pretty confident that this is run like the factory loom. The wiring I pulled was almost certainly original, and the British Wiring harness matched up correctly. Also, I used the diagram from the Haynes manual, and it seemed to be correct as well.
Hope this helps!
Hope this helps!
