bugeye wiring help please
ichthos
When I turn on my lights, the left front turn indicator light comes on. The right indicator light works like it should, only coming on when I turn on the turn indicator switch. Do I just have wires reversed on the left side? If so,which ones? Any help is greatly appreciated.
Kevin
I had the same issue, but my wiring was a mess. What I found to be the issue was that the double rubber butt connector in the grill area was allowing voltage to pass from headlight wire to turn signal wire. I seperated the wires from factory connectors and and ran each one completly seperate
