David_Doan
Bugeye Wiring Diagram - Second Draft
Update 5/22/14:
I learned a few things since the 1st version. Something was screwy on my car before that it would only run if the key was “on” and the light switch was on “S” or “H”. I thought this was a feature of the switch, but my ohm meter proved me wrong. The owners manual also says that only the ignition key is required to start and run. Given this, the circuits are now broken down as follows:
Lights, brake lights, horn, aux. power port are always available. The key switch enables everything else.
New version can be downloaded here: https://doanfamily.net/blog/2014/05/22/re-wiring-take-2/
After a lot of procrastination, I finished the first draft of the wiring diagram for my car. I'm doing the new harness from scratch to accommodate:
What I have done so far is the "electrical" layout. I still need to work on the physical wire run locations, wire sizes, fuses, etc.
PowerPoint and Pdf versions of what I have so far can be dowloaded here: https://doanfamily.net/blog/2014/05/20/re-wiring-take-1/
I would appreciate opinion, critques, and criticism. My goal is to only do this once and hopefully save someone else some time if anyone else wants to re-wire their car.
Thanks,
David
P.S. If you were previously subscribed to my blog, I have lost my list. I you want to get email updates, please go to: https://doanfamily.net/blog/ and click subscribe. TY
Update 5/22/14:
- Headlights
- Brake lights
- Horn
- Lighting
- Parking Lights
- Gauge Lights
- Key Switch
- Ignition
- Fuel pump
- Flashers
- Wipers
- Heater
- Tach
- Fuel Gauge
- Power Port
- Negative Ground
- 3 wire alternator
- Electric Fuel Pump
- Relays and fuses
- Electric Tach
- Front Tilt
Thanks,
David
