I'm having a problem with the m/c brake side bore. After bench bleeding, the piston would work fine, then the piston will bind in the bore and will not fully retract.
I just had the m/c sleeved by Sierra Speciality,(I know they do great work)so I'm sure they did the work properly.
H as anyone had this problem? I dis-assembled the brake side to look for foreign matter and found none. The only way to remove the piston is by a blast of low pressure air.
The only thing out of the ordinary was I switched from silicone brake fluid to Castrol GT LMA. I evacuated the silicone fluid by way of my power Mityvac bleeder.
I am finding small traces of silicone(small bubbles floating in the fluid). I thought maybe the seal on the piston was swelling but I was assured thats not the case.
Any thoughts please.
Thanks,
Ken
1960 Bugeye
