Thanks to all of you for helping with my wiring. I am getting a lot better at understanding the wiring diagram. I have a few last questions I need help with. I pretty much have everything connected at this point except for the heater.
1) What color should the two wires coming from the heater switch be? I think part of my confusion is that the coating on many of the old wires(coated in colored cloth) has disintegrated, and I am wondering if that is the case for these two wires.
2) My wiring harness does not have a free green wire that would go to the heater. There are three green wires plugged into a four way plug underneath the dash. Do I just need to add/plug in a green wire here? I had to do this already for my right front turn indicator.
3) I have one free green/brownstripe wire under the dash, and one free green/brown stripe wire in the engine bay near the blower motor. Which one goes to the heater, and what does the other wire go to?
Any help would greatly be appreciated,
Kevin
Kevin
Hi Guest!
