The writeup said "oversized oil pan" it also said "5 speed conversion". Hole was probably to fit the driveshaft on the end of the tranny. Real 'workmanship'! Makes one wonder what other surprises are hidden there.
That radiator also appears to be a Speedwell product. If it is like the one I bought from Speedwell a couple of years ago (and it sure looks like it), it is an aluminum, direct replacement unit, and a bit north of $500! Helped my cooling problem on the race car though I've learned of much cheaper solutions since then. /ubbthreads/images/graemlins/frown.gif
Can't disagree with the question! I know I'd be replacing the steering wheel ASAP -- looks too "modern" for the application. I'd probably also lose the Speedwell radiator and replace the carb with twin HS2's.
But you ought'a get a load of the owner's reserve price and the attitude the seller (evidently NOT the same person) spews in the Q&A part of the auction. Here's the URL:
Absolutely crazy if you ask me! How to people like that stay in business?? /ubbthreads/images/graemlins/nonono.gif /ubbthreads/images/graemlins/savewave.gif
