Bugeye doors
rossco
The Phillips screws holding the doors in place are hopelessly rusted in place and the heads are beyond turning. Looks as though I'm looking at grinding or drilling them out. (doing pre-paint stuff) What tool(s) can someone recommend that will work within the confines of those tight spaces? I'm sure that at least half of you (or more) who have restored a sprite have had to do the same. Finding drill bits that will handle British metal/screws has also been a challenge.
Get a common "good quality" 1/4" drill bit and go for it, no mystery
Be SURE that it is good quality and SHARP!
If you don't know how to resharpen drills then you may want to get a couple of them since they will chip with use.
Use a "slower" speed on the drill motor if you can- too fast will dull the bit in a heartbeat.
BillM
Mine were pretty well rounded from someone trying to get them out with a Philips. My Makita impact driver and a Pozidriv bit set from Amazon and they came out with little effort. I used a little BP Blaster for good measure.
Thanks to y'all for the helpful tips. Got 10 of the 12 screws out with the impact tool. Had to drill the last two heads off. Both doors are off. Two studs sticking out But so tight and the vice grips barely fit in the opening. I can only get about an 8th of a turn on the studs but the tool isn't turning the stud anyway. Still hopelessly rusted in. If you have any tips I would try anything at this point. Down the line I've noticed both bottom backer plates (with the threads) are floating around loose. How do I engage those if I even get that far?
weld a nut onto the studs
Try heating the plates with the drilled out screws until they're red hot then quench them with water. The extreme heat and rapid cooling will break the bond that the rust has formed between the screw and the plate. You'll need an oxy acetelyne torch to get it this hot though.
regards
mark
Welding a nut on it is a common trick. But it is harder than it sounds because of the location of the stud. Be sure to clean the plating off the nut before welding.
The heat from the weld may help break it loose as Mark suggests.
Soak in weasel wiz for couple days then use a good quality posidrive bit and a impact drill.
