Gray_Cat
I'm looking for a measurement in the cockpit of a Bugeye (59). Moss refers to it as an "Outer Cross Member Section" which is the brace directly in front of the seats. Runs from the trans tunnel to the inner sill on both sides. The right side of my car was hit years ago and wasn't repaired correctly as the cross member is bent. I would like to check my measurements against someone else so if you could measure from the trans tunnel to the inner sill and let me know what you have it would be much appreciated. You should se the outer rocker, repaired with a total of 5 different pieces of metal then covered with bondo....many thanks! /ubbthreads/images/graemlins/lol.gif
