BRSLimited
Ok, so after the last debate as to which clutch I broke down and bought the correct one and not the ebay one, get the flywheel resurfaced, put on my nice shiny new parts. Everything good? Hardly. After putting everything back in I fire it up to go test out my new clutch and the pedal goes down about an inch and stops dead, clutch won't disengage. I pull everything back apart, make sure everything is right, put it back together and the same problem. I can have a partner push down on the clutch while I look and the slave cylinder is moving the clutch fork. What is the likelyhood I got a defective pressure plate? I ordered it from VB and it looks identical to the old one (minus the grove worn in it from rivits). Any way to adjust the pressure plate? Any ideas?
Hi Guest!
