BlueRidge1
Anyone ever tried to buff the vertical grill slats? I think there's 39 or so, i spent much time trying but the anodize
or however you spell it made it extremley difficult to buff the pieces. I found an article that involves mixing a small amount of red devil lye about 2 tablespoons or so in about a gallon of water then dipping the part in on a wire for about 20 seconds. I did this and when it hits the water it fizzes as if its boiling and when I removed it from the water it was acually smoking! Then I rinsed it throughly with cold water and it buffed up really nice with very little effort. If you try this make sure you wear saftey glasses rubber gloves and I even wore a resporater just to be safe. When your done pour it down the drain and it clears the drain also. Has anyone else tried this or know of any negative effect it could have on the aluminum parts or health or enviormental issues it could create? BlueRidge
