Hi Dave,
Although you can convert to a transistorized trigger, replacing your points with the inclusion of a TSV will not only extend the longevity of your points indefinitely, but will be, by far, the most economical approach you can take. Additionally, if you experience a failure in a transistorized SU, there is no way of reviving it as you have done.
I would first take a look at your present points to see if they can’t be saved by redressing. Since most points failures occurring after a winter’s hibernation are the result of tungsten oxidation, they can be recovered by simply cleaning. If new points are required, they are easily installed (
https://www.mossmotors.com/forum/forums/thread/5665.aspx) and adjusted. In either case, I would eliminate any diode or other components attached to the points and install a Transient-Voltage Suppression (TVS) diode.
Since it is common for as much as 200 Volts to build and pass across the points, it is not hard to imagine this build-up as the cause for point flash and burn. SU has attempted to diminish this excessive voltage through the application of a number different diodes, however, their attempts have only met with marginal success and have imposed a Polarity requirement on our pumps. Keeping the voltage below 30 Volts and well within the tolerances of the tungsten points is the primary requirement for extending point and pump longevity but such a component has only come into being within the last decade.
The TVS is designed to shunt excessive power to ground. Since voltage build-up on pump points can approach 200 Volts and cause point burn and flash, this unit can keep that voltage down below 30 Volts (component selectable) when an appropriately selected TVS is applied. The result, no flash or burn as power across the points will remain well within the limits of the tungsten points yet sufficient to burn off the oxidation after a long rest.
TVS Specification:
https://www.digikey.com/product-detail/en/P6KE20CA/P6KE20CALFCT-ND/285933
My choice of a P6KE20CA TVS (manufactured by Vishay), at a cost of around $ 1.50 (including shipping), was made to have a TVS that would pass power below 21 volts and safely allow the pump to operate even if the regulator creates an overcharge situation (could happen). The TVS will react at millisecond speeds to impose a clamping (ground-shunt) voltage at 27 volts to eliminate point flash-and-burn, before automatically resetting for the next points cycle.
The TSV is applied between the top points contact and ground by easily twisting around the mounting screws or by soldering end connectors. Keep in mind that this is a diode and must be installed in one direction. The ground end is sometimes indicated by an arrow but also may be indicated by writing on the component being read from the ground end.
The cost and longevity of a points/TVS trigger on the SU pump has made it difficult for me to justify changing to a transistorized trigger. One last benefit, a points/TSV combination is NOT Sensitive to Polarity.
Hope this helps,
Ray (64BJ8P1)
