Blonde Healey Girl
I have a 60 BT-7 that has a solenoid between the carbs. (Car has been sitting for 22 yrs. drained the tank, cleaned the bowls, messed with the pump, installed cheap inline filter) Anyways, I have no idea how the proper operation of this choke should work. It seems to draw fuel from the back carb, then has this solenoid that clicks when I flip a switch under the dash. Has three rubber lines that flow directly to the intake manifold. Today I pressurized the fuel system for the first time. The bowls were not overflowing through the overflow tubes but the pump never fully quit pumping ( click every 5-6 seconds) but after 2-3 minutes the maniflold drain was dripping and one of the 3 barrels in the solenoid choke thing was dripping. I tapped the floating solenoid with my finger and that seemed to stop the dripping?Is this correct operation? I never flipped the switch nor did I try to start the engine yet . Thought it might be wise to consult someone who has "been there done all that" Thanks for any advice!!! noticed Healey did away with this design in 61, is the old pull choke a better way to go?
Hi Guest!
