I have a '74 mg midget. Has a 1500 engine in it (1275 is standard for the '74) a previous owners installed the 1500 engine and transmision. Last night I had my passenger wheel studs brake off while I was driving (no damage or accent to the body or me thankfully). I was able to get a tow safely to home.
I have some of those minilites wheels installed.
When I installed the minilites I installed new wheel studs (either from Moss or VictoriaBritish, can't remember where I received them from) since the original studs where a bit beaten up. When I installed the lugnuts for the new wheels I torque them (with a torque wrench) to the require spec from the Haynes repair manual.
Maybe the torque spec needed to be higher since these are not stock wheels?
Any idea what the torque needs to be different with the minilites installed?
The studs broke off by the head of the stud next to the wheel bearing hub?
Other than loose lug nuts any ideas of why this failure occured?
Maybe the studs where a softer material than required?
