I was looking at the carbs on the TR6 and noticed that one seemed to be frozen. I took them off and one is ok. Probably needs a rebuild but the other is not in good shape.
The slide (Air valve I think) is frozen and will not budge. But worse than this is the throttle shaft is actually broken. It has cracks around the throttle plate screw holes.
I am going to leave that carb to soak for a while and see what happens with the air valve. Also , the damper won't come out..it also is stuck.
Can I replace a throttle shaft?
Thanks
Thanks
