mrsprite
I finally broke down and got the speedo kit from Rivergate (two years of guessing my speed was enough!). I hooked everything up and the odometer quit working after 2 miles and the trip odometer won't reset itself after pushing the button. The speedo works beautifully and is pretty accurate too (at least according to the "your speed is X" traffic signs).
My question is, is this a common problem with the speedo? Is it easily fixed or should I just buy a new speedo? If I need a new speedo, does anyone have one on the cheap?
BTW....I have a Bugeye, but it has late 60's Spridget gauges.
FWIW, the speedo in my BE has been non-op for about 15 years (no cable hooked up), so it may have been busted to begin with. I did lube the speedo with some oil prior to the cable hook-up too.
Hi Guest!
