RJS
Hi
So, some of you may have seen my post about a week ago re Head Leaking Coolant after Cooling System Flush
https://www.britishcarforum.com/bcf/showthread.php?108056-Head-Leaking-Coolant-after-Coolant-Flush
I found the problem. Broken left rear cylinder head stud. See attached photos. Apparently it snapped right where the threads enter the block. It was as loose as loose could be - just floating there in place.
So, I'll definitely have to pull the head in the spring. Look at the photos too - it doesn't exactly look like a recent break (would you agree?) - kinda odd. So the question is how long has it actually been this way?? And in a strange way, I am actually somewhat relieved this wasn't caused by my "cooling system flush" and that it wasn't a head gasket failure.
Earlier today when I first discovered the head stud twirling with no resistance I was really scared that it had stripped in the block. That would have been a nightmare to drill and tap a size larger. This won't be simple but, at least I am pretty sure I can extract it and simply insert a new stud. My understanding is that head studs are only supposed to go in finger tight. If that is true, then maybe it will come out without a huge battle.
I'll be soaking the manifold nuts weekly for the next two months in prep for removing the head (the car is now stored for the winter). They are extremely rusted and I anticipate big problems getting those off. Probably bigger pain than removing the head itself.
Appreciate any thoughts you may have on extracting that stud once I get in there - or any other comments or ideas you may have on this problem.
Bob
PS: coincidentally, in June 2006 a so called "British" mechanic said he removed & replaced the head due to a so called "oil leak" (which I had never noticed). The invoice said he planed the head and installed a new head gasket. I never requested this work and he charged me $500 (not happy!).
Then in the summer of 2007 (~500-700 miles later) I first noticed oil leaks coming from literally everywhere – timing chain cover, oil filter housing, fuel pump, oil pan, valve cover, even the bolts attaching the ignition coil to the engine block! I spent years fiddling with the PCV system and improved the venting on the motor. Although the leaks are not as bad, I still to this day have leaks from the timing chain cover, oil pan and rear main seal. Now I wonder if that mechanic cracked the head stud back then and somehow (not sure how) that was allowing combustion gases to pressurize the crankcase all these years??? Does that sound possible? If so, then I am kinda encouraged that this repair may also solve my oil leaks.
Bob
Hi Guest!
