British Wiring Harness--Can I buy front section on
Bruce_B
With the engine compartment totally stripped, lights removed, etc. I took out the front wiring harness that runs underneath the BE bonnet.
I'm thinking about replacing it, but does anyone know a source where I can buy ONLY the front section?
Bruce-You might want to check British Wiring's web site to see if the front is a separate piece.
Jim,
Thanks for the advice...already checked the site. But I think I'll send an email asking if they sell just the front. Doesn't hurt to ask.
Wish I knew the BE systems better. For mine there's three different harnesses. There's the main trunk for the engine bay and behind the firewall, dash harness, and the rear section to power the fuel pump and rear light assemblies.
From what I've seen Jim there's a section for the engine bay, one for the gauges/ignition, etc., and one for the fuel pump and real lights.
BEs have three harness you are correct, however.......
behind firewall, in front of firewall, and dimmer switch.
